After.If I change things up and go with a CSV where then do i tap the output to the irrigation system, before or after the CSV
Not with a draw-down seal. only reduced productionIf the well wasnt keeping up with the pump would I hear air in the sprinkler as they are running?
I don't know that water levels matter with a draw down seal? I would think if the well is not producing enough it would act like a restriction to the suction side of the pump, but the water level would not change. The pump could be tested in a barrel, bucket, kid pool, etc., then you would know if it is the well or the pump not producing as it should.
The water levels dont matter since he has a seal, but if he didn't it would. Chances are the screen has been or is getting plugged with iron which will reduce flow to the system. That is consistent with VFD, CSV or conv. Pick up the pump and test pump over the well head to test production. If that does 20 gpm at 50 psi the pump and well are fine. IF it doesn't then you need put the pump in a test station (barrel) and verify if its the well or pump. If you have a ton of Iron or Iron bacteria. you might just plan on replacing your pump every 15 years of so. ( Again regardless of system, VFD, CSV, Conv) If its the well you may be able to acidize or scrub it. Any pump guy should be able to do this. Some just make the pump hit water so you have to pay for it.
I am wondering about the PVC pipe going out to the irrigation. Should it have a valve inside? and maybe something that could be used as a drain or blow air to help Winterize?Does the other part of the plumbing look ok.
