Connection to water meter for irrigation system
Manny
Louisiana
I’m looking for suggestions on how to connect the main line from the water meter to the house to install an irrigation system.
I have a 3/4” PEX pipe from my water meter to the house. I need to put a tee on that water line to connect to a PVC pipe. Do you have a tee fitting that would connect the 2 different pipes?
Do you think a SharkBite 3/4in push-to-connect x 3/4 in push- to connect x 3/4 in FNPT brass expansion tank tee (like the one below) will work? It has 3/4 in female threads that you can use 3/4 in male adapter then bushing up to whatever size you want.
Thanks
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Push fit type fittings are not recommended for underground. They tend to fail underground (I do not know why, specifically).
