Connecting Threaded ABS to PVC
24SevnLibrarian
South Carolina
Hi, all! I am living in my grandmother's old house, and I changed out the bathroom sink when I repurposed a dresser as the new vanity. As part of the updates, I am adding an AAV, because the lavatory is too far from the vent pipe. The new sink is several inches to the right of where the previous sink was. The old sink consisted of a brass s-trap to threaded ABS in the floor (see picture). I am planning to use 1 1/2" PVC p-trap, pipe and san-tee with a Studor Redi-Vent set up much like the attached picture from the Family Handyman, but I am stuck when it comes to figuring out how to connect the PVC to the ABS since the 1 1/2" ABS is threaded. I would love to use a slip joint connection to the ABS, and I feel pretty dumb not being able to find what I need, but if you could recommend a way to do this and send me a link if you know of a specific part I can buy/order, I would appreciate it so very much!
1.5" ABS or PVC Female adapter and three wraps of tape on the threads. Hub x FPT
Get whatever adapter you need depending on the pipe you're buying.
I am not a plumber. I think I might saw the vertical chromed pipe in your S-trap picture to create a vertical pipe. Then with a new trap adapter (ABS or PVC as desired) connect to the newly cut top of the chromed pipe. You would end up having 3 trap adapters, as I picture it.
If you did this, you might want to add a support of some sort.
