Bilbo6209
Hey all,
I was installing a new kitchen sink last night and went to disconnect the PVC stub connected to the steel service pipe coming from inside the wall, and the steel pipe broke at the threads in the wall (iron had rusted through due to crud build up in the pipe) without pulling cabinets off the wall there is no way to get a wrench on the pipe or 45 elbow (I was able to get a wrench on the remains of the threaded pipe and all it did was deform due to the rust eating all the structural integrity out of the pipe). I thought I would start down at the clean out in the basement, threw a wrench on it and the entire pipe basically fell over due to the threads rotting off inside the elbow... The outside diameter of the pipe is just under 2". So I went to home depot and bought a 2" Fernco service weight cast iron hub to 2" school 40 PVC compression donut but obviously that doesn't fit... I wasn't thinking of ID vs OD 2" PVC is 2" ID not OD.
What is going to be my best way to connect, I'm guessing 1 1/2" PVC drain pipe to the cemented in elbow that is just under 2" Id?
