Connecting my new existing sewer line to the lateral
bmklawt
Grand Rapids MI
Me and my neighbors sewer lines are connected together under my neighbors driveway, the city was going to be redoing my street so I had a new 4" line sewer line bored from where my sewer exits my house to the location where the new lateral would be. When the city did put the new street in they did put a new lateral for for my house but did not hook up my new sewer line, they hooked up the old sewer line that is shared with my neighbor, to be clear my neighbor and I both have new laterals in front of our houses that terminate 2 feet towards our house from the sidewalk.
My question are how do I connect my new line to the lateral as I will not be able to glue the last joint, can I use a Fernco rubber coupler that I've read about.
Can I use the white PVC pipe from from the box stores to finish the connection.
Can I glue the white PVC to the lateral which is green pipe
What degree elbows can I use to connect my line to the lateral, my sewer line is 4' deep, the lateral is 6' deep, I'm assuming I should not use any 90 degree elbows
How do I terminate my neighbors sewer line when I disconnect from it, it is clay tile.
Your help is greatly appreciated,
I only seen green sewer pipe never seen white ? , the white that I see is sch 40 dwv PVC which I belive is always a step up from sewer pipe higher quality more expensive as are the fittings . generally I use 45 degree fittings with a test wye directly on the lateral . sewer gets tested with water up to top of slab geneally or as high as practicle lowest fixture perhaps
abandoned pipe dosent need terminating as far as I know. 4inch clay mission band and plug is typical im sure there is another proper cap nearby plumbing supply has not a big deal to pick up there goes another 20 bucks lol .
since youll have 45s you should be able to glue it together just lift the main up and push it together at a 45 . start at house going to sewer then when kinda close put the test wye on and figure out your pieces to gett a fit up between the 2 elevations itll take a little dry fitting and guess work to get the pieces lined up just dont cut them short LOL or youll look dumb with extra couplings !
Breplum
Licensed plumbing contractor
San Francisco Bay Area
There is a white PVC available that is called Sewer and Drain (S & D). That is NOT for sewers, it is for rain water lines only because it is not heavy duty. Schedule 40 white PVC is fine for sewers.
If you don't have a cleanout on the end of your home you can use a two way cleanout or two wyes facing both directions to allow cleaning out the house line in a pinch.
ONLY use shielded Fernco type couplings, NEVER use unshielded and preferably choose. Best to use what Fernco calls Strong Back couplings to resist earth shear forces if your pipe is more than two feet deep. https://www.fernco.com/products/shielded-couplings
Mission Rubber also makes them called ARC
In a pinch, you can cut out the inner stop-bead to slide on.
Sylvan
Still learning
New York
I
Mission Rubber also makes them called ARC View attachment 100257
I like the idea of 2 cleanouts facing opposite directions..
We did that for a clay pipe that was installed in the late 1800's and the line had root infiltration from both directions
I never used a Fernco even though it is allowed in some areas I held a plumbing license
Note that there are similar but different sizes. SDR35 is one size. Schedule 40 is another. You can transition, but you have to know what you are connecting.
I suggest this:
These cheap digital calipers can go thru batteries (in a month or two?) when not being used, so either keep a spare, or remove the battery during long periods of non-use. Looking ahead, order maybe 5 replacement batteries via Ebay. LR-44 or 357 are some of the batteries that fit. In a pinch, you can get them locally, but they are a high-markup item.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=357+batteries&_sacat=0
In 4-inch nominal pipe size,
. Schedule 40 OD: 4.500 ID 3.998
. solvent weld D2729 sewer pipe: OD 4.215 ID 4.056 ( white or green)
. SDR 35 OD: 4.215 ID 3.97 SDR 35 (PS46) ASTM D3034
SDR35 has a heavier wall than D2729
Schedule 40 has a thicker wall than both of those. Some is DWV-only (foamcore) and some is dual rated DWV+Pressure (solid).
https://www.fernco.com/plumbing/shielded-couplings/proflex-couplings are not for underground as specified by the manufacturer. Their "Strong back" and XL couplings are suitable for underground per manufacturer. Not sure about the Fernco "No-Hub"; probably OK for undergrounds or above ground, but they are not as explicit. Those come in standard, medium, and heavy. https://www.fernco.com/products/shielded-couplings
