I am trying to understand the proper connection for a 4" horizontal main to a 2" horizontal shower/tub line. There is about a 6 to 8 inch drop while at the same time transitioning from the 2" tub/shower into the 4" main. See photos of two options that I could come up with. Note the photo does not show the needed 2 x 10 perpendicular joist that will be installed, one on each side of the 4 inch main.
Option one is a 22.5 degree elbow with a combo T. The combo T would be installed at about 22.5 degrees.
Option two is a 90 degree elbow connected to a sanitary T. The Sanitary T would be pointed straight up.
Are either of these options ok? One better than the other?
Thank you
Thank you
