Yi Ma
I had a look at the following thread which is now closed: https://terrylove.com/forums/index.php?threads/submersible-pumps-and-multiple-check-valves.26301/
The diagram at the top says that there should be a check valve directly above the pump, but all most water pumps that are described here seem to have a check valve already included, so am I right to assume that no additional check value is required immediately above the submersible water pump?
