Bob from accounting
Hello Friends,
Need some advice on a wall mounted utility faucet.
I am currently installing a wall mounted utility sink in the garage. It has no area for a block or faucet, it is flush to the wall. The Pipes will be exposed coming down into the faucet from the top of the wall.
I need to mount an economical utility faucet to the wall using the exposed pipes. (faucet needs to have at-least 9" spout and can connect to a garden hose.)
(This is an example, however this has a short spout, the inlets are on the bottom and not on the top and this is a bit out of my price range, but a good example)
All my pipes are clipped to the exterior of the wall, so these do not stub out which seems to be what most wall faucets require.
So I need to figure out how to plumb a wall mounted utility faucet that configures to exposed pipes.
A majority of all the faucets I have found plumb into the wall or need a block to sit on.
Can anyone help me configure a way to do this or point me in a good direction?
Thanks for any tips.
