Condo needs help preventing electric hotwater heater leaks and damage
Discussion in 'Water Heater Forum, Tanks' started by Clydesdale6, Jan 13, 2019.
  1. Clydesdale6
    Clydesdale6 New Member
    Oct 14, 2018
    NY
    I am on the Board at a condo and we have been plagued by electric hot water heaters leaking and damaging the units below. The HW heaters are in a small closet and most do not have pans under them, as there often isn't enough room for a pan. Any suggestions? Any alarms? Any other devices that may help prevent this from happening. I have a filter on my HW heater and the filter often turns pretty orange in 3 months. The HW heaters tend to rot out within 5-7 years. We are considering mandating some sort of solution. Suggestions? Thanks.
  2. phog
    phog Member
    Jul 29, 2017
    Rochester NY
    Hello, there are many leak detection systems available that will shut off the incoming water valve when a leak starts.
    All that is required is a catch pan installed under the water heater (which really should be there anyway), and an electrical outlet nearby for power. If a leak starts, a water detector in the catch pan will send a "close" signal to a servo motor that attaches to the inlet valve.
    These systems are not very difficult to install and relatively inexpensive. For example look at the Taco LeakBreaker or the Floodmaster systems.
    Incidentally, another common area for floods is clothes washer connections (rubber hook up hoses can burst). There are similar shutoff devices available for that as well.
  4. jadnashua
    Most all of the systems that can protect require a pan or dam of sorts to hold enough water from the leak to build up enough to trigger the device. There are some that can be glued around the tank so they don't have to be removed first to install one underneath.
    IMHO, probably the simplest device is www.wagsvalve.com - no power required, free damage insurance IF installed by a licensed plumber. No power, so it would still work during a power outage.
    While not 100% effective, some condo associations require owners to replace their WH at a particular schedule, regardless of whether they leak or not.
  5. Clydesdale6
    Oct 14, 2018
    NY
    The wags looks interesting. Anybody have experience with this or another device?
  6. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  7. WorthFlorida
    WorthFlorida ?
    Oct 28, 2009
    Retired
    Orlando, Florida
    There is probably no room but every condo water heater needs an expansion tank in addition to drip pans and alarms.
    Rochester NY area gets most, if not all of its water from Lake Ontario and in winter months it could be in the 30’s. That means a lot of expansion when the water is heated. https://www.weather.gov/buf/laketemp
    When I worked at Sears in Syracuse NY area, we also had extremely cold water. Customers coming in for a new water heater and all said the samething, they heard a Big Bang in the basement. It was the water heater literally cracking wide open, not a pin hole type leak.
    Reach4 likes this.
  8. phog
    phog Member
    Jul 29, 2017
    Rochester NY
    I'm not sure where in NY Clydesdale is from -- I'm the one in Rochester. Bet you miss those snowy, windy Syracuse winters haha ... not!
    But yes, very good point about the expansion tanks. It could be part of the reason for the short lifespan on the complex water heaters. Even if the incoming water temperature isn't 32.001 degrees like I'm pretty sure mine is right now ;-)
  9. WorthFlorida
    WorthFlorida ?
    Oct 28, 2009
    Retired
    Orlando, Florida
    I didn’t realized the location. I was looking at the avatar, however, most of NY state has cold water since lakes and reservoirs are mostly used. Long Island, NY has about the warmest water in the state because it is ground water.
  10. Clydesdale6
    Oct 14, 2018
    NY
    I'm in Putnam County NY. About 1 hr north of NYC. There are many condos with just an electric HW heater.
  11. jadnashua
    An expansion tank never hurts, but may not help. Where I live, it is a code requirement, even if it technically doesn't 'help'. Most utility companies are installing check valves on their supplies to buildings, and once that is done, an ET is required or the tank's safety valve will often open because expanding water has no place to go. This may or may not be a huge issue in a big complex, because all it takes is one leaking valve, and that expansion might be released without raising the pressure.
    There are lots of water sensor alarms out there. There's a fair amount of valves that can close the incoming water to the tank after the sensor says there's a leak. The only one that I've found that does not require power is the WAGS valve. It DOES require a pan so that the water level can rise (3/4") to trigger it. Many of the water alarms will trip at a lower level. That assumes you have power to make them do something.
    Often, the simplest solution is also the most reliable. The WAGS valve is pretty simple. It's a one-shot deal...once triggered, it must be replaced. A water alarm should be tested periodically...how often do you think that will happen in a condo situation? Alarm fails, somebody unplugs it, or forgets to replace the battery, and no protection. That assumes that the valve works, too, which also requires power.
  12. phog
    phog Member
    Jul 29, 2017
    Rochester NY
    Don't multi-story condo complexes usally have check valves & vacuum breakers at each unit's service connection? (Each is a potential siphon point for grey water in the event of a mains pressure loss. )
  13. Master Plumber Mark
    Master Plumber Mark Sensitivity trainer and plumber of mens souls
    Feb 6, 2005
    Sensitivity trainer.. plumber of mens souls
    That Wags valve is a one time shot and I think its a joke in some ways... once it gets wet
    for any reason its done and you got to install a new one....
    I would find a metal man to fabricate a square pan to fit in that room then require the pan to
    be installed in every condo.... I am assuming that their is a drain in the room for the t+p valve??
    we had some expensive condos where the dumb ass builder did not install a drain at floor level
    for the electric heaters and they would break and flood the people below them.....
    We installed the heaters in a washing machine pan..... then we bought a small condensation pump
    and put that in the pan and piped it up to the drain near by.... if the pan got more than an inch of water
    in it then it would come on and pump the water out.... also their was a zircon water alarm in the pan...
    the biggest problem was no one cared about the folks below them.. I think they thought it was funny when
    they could dump on their wealthy neighbors and ruin their condos..... I guess some rich people think that way....
    you will have to mandate and force them to do this all at once and get a plumber to do them all at the same time or its gonna never get done....
    even if they are worth millions they wont spend a dime for this unless they are forced to....
    [​IMG]
  14. jadnashua
    The beauty of a WAGS valve is partly the fact that it is a one shot pony. It's quite simple and the tech is the same as that which inflates life vests that sit unused for potentially years underneath your airplane seat. They're reliable. No power, no batteries, it just works.
    An alarm is useless if someone is not home to hear it. And the less complicated, the better. Just don't pour water over it.
    Master Plumber Mark likes this.
Similar Threads: Condo needs
Water Heater Forum, Tanks Water heater installation affecting condo central heating system? Nov 22, 2014
Water Heater Forum, Tanks Condo, under counter WH, replace prior to 4/2015? Oct 29, 2014
Water Heater Forum, Tanks Opinions on a replacement EWH for a 2nd story condo Feb 8, 2011
Water Heater Forum, Tanks I have a A.O. Smith Power-shot water heater. It heats fine when it needs to but the p Oct 9, 2012
