AndyfromQuebec
Noticed some dried rusty water streaks on the outside of my 8-year old Giant hot water heater (172ETE), a Canadian-brand that used to be revered for its products longevity. The streaks were coming from the upper access panel, so I opened it up to find the batt insulation underneath sopping wet. There was condensation underneath the plastic vapor barrier in the upper right. This area appears to not have been insulated properly.
Water had accumulated at the bottom against the foam and appears to have seeped below to the bottom access panel where visible rust is present and flaking.
Since I've removed the panels and let things dry out, the condensation has pretty much stopped. My questions is would the gap of insulation be the cause of the condensation. I guess it could be leaking from the inside, but we have soft lake water here and the last model that we had here from Giant lasted 25 years! Tech support has pretty much washed its hands on me since it is outside warranty. I'm likely going to have to replace since that rusty spot on the bottom has a mild softness to it.
