Condensate to drain connection
Ernest Le
Los Angeles
My contractor ran the HVAC condensate drain down from the attic but did not tie it into the sink drain. I bought a branch tailpiece but my current faucet drain pipe runs down too low and I can't get the branch positioned above the P trap. Do I have to replace the existing drain that came with my faucet with a shorter one?
You can use a hacksaw. Yet that alone will not be enough.
Can you reverse the U of the trap to make the input lower than the output of the U? If not, you could replace the trap I think. It looks like you have a trap adapter at the wall. If that is the case, it would be easy to replace the trap with one that has a reversible J bend.
Another possibility is to put a hole in your tailpiece, and clamp on a drain saddle. Condensate drainage may be slow enough. https://www.appliedmembranes.com/me...dle_installation_instructions_for_home_ro.pdf I am not sure that is a good idea, but it would get the water routed. Would there be clogging due to the small diameter later? I don't know.
Ernest Le
Los Angeles
Do you mean something like this? I would have to cut pretty high up. What is the lowest level for the branch that would be acceptable? Would that make the trap too deep? Thanks
VLt1s8Ej_DOoqmu1XTjhthJ4lc-5gQBCQid_KU4FxGhGd7QjVn_WI0r5f6MeSZ11jp99WScQrlMw8EL8CjlhlBuGJzImfrZaMXUvMpf40HC8Mg2U6s-mWIMrHjxIjMmo_nZCwRqiXDBuKWWd4JMcnLs_RQ5unf4HlfNn315LwsCRohfBSl2welHjHF3rJedkNoeZCDS-TWwWBknTD7tl-CAb_eImE3vCF2CpH4z_CKDjVeAf6dQJR9j1B8HZHyTURGZFDp5kum41QwxsMSO9ahOzcNEWPijpyQ0JqK1ACi9RzU1p1WnfpNNXlHyQEwcBBKke2Hx2wId1FLFkP5QZzalO9YWK1Dp8CVtiAIJ6FIxhmAPRLAvK7sSghc_ldLaCZK1rZCQCgsYANgkAvM1M3Sf74b7MQaOYssztyiz4INMM7_Rp4DEtLUVq-FPdt9NPzJMCJShKauPPRSb_U-7zi8TJHfrVwoU_swXza06V94M6rxPXrX6SbFwBz6-FSib2LJk4EEemUZX5NO2nj0CfYSyYnueL_7GPvZdNZHqkc1hEMYSdoyrTVaoGrV3TOQGcXMJxn5rkZqFwDHCClhMGtZLjqWw_hAI2kdERNU3MlbLG58oKTW6trhrcXVVYnHD-f50Ui2U2ejC0PLp058sTAYy7ua9q9yGlr1chnVfZYpADr71SOxTtaySQIG1Xu24=w640-h1137-no
Yes, but you would need to bring the branch tailpiece extension down to the smooth part of the tailpiece.
Keep the yellow dimension under 4 inches.
Plumb Pak® 1-1/2" Brass Dishwasher Tailpiece with 7/8" Branch PP142CP seems to put the branch higher.
Oops.. that is a tailpiece rather than a tail piece extension.
Ernest Le
Los Angeles
That would put the branch below the outlet. Wouldn't that be a problem since the connection from the condensate drain is always under water?
TASVbkrNabBqj8uR7-icy8RkKqur9IQ4LliFH2UDLU0BBfzvNjGeVI_Emj8Mb9M_VdTlyc2ZLQzsbtNvNZP0EJmqS5_sBJpnk1hvbP8XAdF9F89nfwwjmE7AjuY7QgeUHPVF6MX4Lig4F4DOhUwwuRcNAKRfeXf_rh-1gI7yWzxiym0SONwTf4_f1jqsjl7mJfelXUg-8CzoG1fFf-ARqZCnzytEnwfyCrNvjPfXDmZzXKKOpM5iVpcuoWDPSnV27eT8fGV8Eya3RSSgQdyGKFCnQFXM94ggzbBZR55lO_eGDOKYEIpWO4yr4tCVyESfQZJVbI3waopTN3OngbkNkXYUOOLqIq84MccWUJpfiJ3iauPlYJCl5b_PnbdAXJoDV5nKU2uhYrP1qgdiVobd2A4zPA_OUaqpvOBclz_kGEq3pC66PnYXBf9jHs6k178eyBpKDVgc57RFv8e_ePsYbIRxHtTCxhFKHncxFzNzy9TGsmCiWAT63ScrOy28D8hAxYirl24FGJLUcnImMctGbRtiQCgEFespKORoqA-bsDlSEF01Iect5nNKJyQni3l-hxaKAtxKPj7Bjj7OsQ_CPmI_q8o3nsMiKs1Q9QB1YH4OW0dmix17orcRrc8WhzYQwJH89aT-mW24KYvmcYGoJPwq_q7H1mCGBQm7VwmRxvnLJho_sz4-TlyRD7slrqM=w640-h1137-no
Given the acidic nature of condensate I wouldn't use anything metal in the drainage connection...
Drainage from combustion, like a tankless water heater or a high efficiency furnace would be strongly acidic. From an AC evaporator such as an A-frame, I would not think you would have a corrosive acid.
Ernest Le
Los Angeles
I replaced the tailpiece but the branch connects right where the nut used to be positioned
GhTwgDMCvEk_Fh0LH8nAMu0YCKUW1ovY3xhe-cPg8ztELuYIzjEopct-unsWRjJhB5sE28zdBW9Dt-Dk8CWpF8rdptxahIcCcfyLcinYRn3Bg3r4YlhOWchicP2zCkzbqxnHoKitLdoBx0UUq2skKYG53NF_pWfgyhDFnIL8QhNz1rMyZtpRQmP4sHAVMrGqAx2blWaKBKgWZ-nSKS4zmirMGB-pxGYRcmbNsFrzKtcGYIpThqZjmFpsNS8NCkHLMc4oFQ0UHhPTPXKT_pfK9Ak26ab9i1iSi-brnXv2vR_o5ZRidOuvH-fetrZWjh6U-MxhHff-L1z-Ai5hY3MRxf9QU4lOi_bLmMc8d-5DlubjWHoHwVXAH6S4D0teExfQrBRq4ZrO8vx6dvH7RjsJ5BGLyebuCPwATntvnhdJTtHta8QJnixGjf5EJUkX5yot1enRXwMfuvb1JWZljRuNQ6n9g6iosT-xAQLFoSVGTaljlwtjUOovwci9mjZdx-e3PCOtCXO7epaHscnc-kXOPk9D1kfKncdjZ2jE2iBRuwTnVJpgAifd4szXbZDfYfWGj5Ql8OOktjUlii8bDoDVqC7KBssFoI7hjXi54Z-B-GE0Itj8mfXcraJGo4X5WdMbxHXqqefC_jTJB232aoHc3usvC9KqGFMbR0HBdehLWkLBUN25xhIi24UGfvVn2uQ=w567-h1008-no
If I connect the nut, then the trap doesn't quite reach the waste arm
c4Gb3_RFbUCgDaKBHBxY5CLk-XDuzQ7wdor53wD2pw2mlkkAWvDm3jMFMPhoRht7UZWIUdyw2bo0tUiX2swvtxt9JOTV5_c3buBnrs4APtbdoXw5OZb7hRj0JTozhV9SrHyd_CfzPcubGi4iDkuOgaZAsKuFXAlz2klxlAL_5yn60spE8VALosY2JOba52CL0yeF_7MNQZWq1KgUlWlQFi0LN5bJYsY1ZAlxNJ0YHhJP3c5NE0GDzKIaH9a1vPmUvDOUQQ4tDvchUu09CkXbli6aqOwo33cfxsyhd94MMzLVVhXt0WVxIQCDUi7r7s7vfWrz4_Cyz95X0uLQxkMD70c_uHA3e8BBlycdwOYekLgT01GPacl1F7DhKhCcQrxKYJO6WtPgK6VcY8OATEXjIA5X3BKPNQWSl-Q_O6Mc25taetevNfwkQzcQUQxpCdQk8Klw7M8IML7dXnRqeqbBjbV7KRDcCzGHHyU3vAfOI7MIWgD_XK_5OI5e4WafwIng9DyVS737dDQL-z00250MTjREsDnwz8CgSOJQHXi8jwSCmnp0U9LEOPYlOFUJxRxJPTr2ypj-8FcVpmWcFOg6rkVYFhBZqvcDbUTeEts4NoQYgMHNAMSQx5lKnxgDoRrDQI81ypPUcw3rezBqihylcpCB0c9enMZ0r1eNy1nx7s6KlTsgrX4Zgn2eOQWIrGo=w1792-h1008-no
Should I look for an arm that extends further down, an extension to connect the existing arm and trap, or a deeper trap? I'm short on either end by about a half inch
WbJJgF5KfIrSIBLFmAO5yTTWCSxhHj5mnrObaCFQSOushoQx2lFAo6aXE0GJHVirnMHI4-34WqMA6IqZK_EwXoGlHlKrcSoqGIWRtQg4D9o1uCJ4rKnEEumgX5-sjdD23JJw1R5SItYyvIRS3iFr1X8_r-Tsux11Ylea8VaqSuN5Ooe4AtGMnhnCfhtbOYnPT44t1mVXWYMsvRfYPe9zdMYunrvbBYawT7L_kiR8unWOk37cwtPUl7GsNA9VGq4YI5zeisFoK4bFJOPRcSUTsWhNH3_-MZ-wPDw1wJciqNXqb5b-s8SCT0eGC-BNt-8k4Vq-reOF1Z2TiOiFAjsCtVD6aYs4SlLANS3a0HXfnx7PxqMjzR2MJLLoRh27PYCde68doYFNCmA4QcY3vaxNoQyNWFr-wEHVRDUSDIIgdm8EDvvqMgpJxprWbAkTEIPfphPCQ2rNsBkyqFRH_Mwawg_fe3FUypobducsin2AVKcbYMLc4UaggsW8JGbrBqwuwd6vw_5yEoDqHZlKFp0fEQPm9xKj1qmslHMFtfnXl0fqbnRus7cT29B6gmglrF-uCqTxu1cmuXgKiQgelIRaMIkvTM0V_uqOTJw_9JPtS4W8NSgHO_Q7F_e7_IpiAMsSk0QTWIWcGbojKdsv7_5EdIbMUt_Z7JcxDG02OqAZ0xKczSYbyJmMJW6cr6k5J6I=w640-h1137-no
jrF91l-myP9A5-jcYyNmNK1K5r6uF9s3tLhxaAMgvGbIXM9NR1Y0slTZ-Z8fbmc-c0ByPmFpZcyc73mu5RWRHIQ7R38qmvG_0cL7OUaVMXZhHQ4DOjh4u1lndjI46MFO_VGpfvuPo8XPalkUvKCgi6w3Nr5K_jp8WR9ViEA7QYVCa4DE-edwqapxLr3343IAGp1JbeQ-pQf4rt2LOAOztC_oM3mDGuO71VhFrBLNhRCoLrBqjRDNq3byR44eLbqP7w39XEtUyf6KzIm01BP0MmNrIdYL47GQOpr0xikhib-cBrE9daByIGL-qnkBKcvrcTvf1JSwon0G52vTViuqjy1ikZOFQmcjQ53zJj-kaM_nuVO4KMEpMArq6bh9fXDtoDeqD-uzGMjNj8eE6bgKGr9Xf2Nqbq8puSIgtZHw9L0oSTrtw0nyHValSWj3NB_FiI76OMB8E8mKOEoLDVZXsGHLj0CoE8opsr2PJ1OTnILMwHmKAfjaqXeOIAjumRQNFTJ4aA6pJeezqzBg5t7eIVyQUEXgcVKVRIqQU3vQVdQCXDIEvPQZiOC1JpvRKT8QpSU70_mwUygC1wwqq87PKLSGJlp1waZ2KSZ2Jp3eUeQqi1lHQUSGeMv6wL3zStMGD1p6y7yzlbFPbXcBOl6SfKvFxu3krFcVc8SxADl9PJNNXHO3xEK40SFZwbFuDAY=w1024-h576-no
Should I look for an arm that extends further down or an extension to connect the existing arm and trap?
The images did not work.
