Erico
Temporary fix: my brother in law took vacuum line off to check diaphragm by sucking on it and got a mouth full of water. When line is emptied the furnace starts and runs.
Mother in law has been pulling top gray line and emptying it for the last week.
I think the condensate pump is not working. She says she hasn't heard it kick on.
There is standing water in the tray not shown at top of PVC line on right.
I see the a-coil drain line lower left. The drain upper right, I assume, drains furnace. This is a high efficiency furnace. Down draft. Over a crawl space. Apparently the drain exits the pump and goes to the crawl - I assume entering the drain system? Need to get in crawl and confirm.
Seems silly to have a pump for water going down hill. Or is the pump required to evacuate the system??
I can get a pump for 40-50 bucks. In the mean time, I'm thinking of cutting the PVC, removing the pump and draining in to a bucket tonight to see if that solves the problem.
Either replace the pump or drain everything in to a trap and then the plumbing drain.
The fact there is even a pump to a crawl is a mystery to me. Or is the pump necessary.
