muddywell
Working on a different plumbing project I noticed an old condensate drain line running towards the main 3in stack (the new HVAC uses a condensate pump to outside). I followed it to where it ties in and was frustrated to find the installed had just drilled (and tapped?) a hole into the back of the main cleanout tee and threaded a male adapter into the hole with what looked to be a large amount of PVC glue. There was evidence of a leak and the male fitting was loose so I opted to try to seal it up a bit better. I was able to wrap enough tape around a 3/4 threaded PVC plug to get it to seal for the time being.
I'm all but convinced that the only real fix is to break up the concrete, cut out the damaged tee, and replace with new. Before I jump in or hire a pro, any other ideas? I should note that I'm planning to finish this basement area in the near future.
If the tee does indeed need to be replaced, would there be anything wrong with raising it up 6-12in off the floor to make access easier in the future (adding finished floor would almost make the plug inaccessible as is)? Also, is this style of cleanout tee appropriate here, or should it be a sanitary tee?
Thanks,
muddywell
Thanks,
muddywell
