stormlight
Hello all,
I have a 21 foot well. 10 feet to water then 11 feet of water. 4 inch casing pipe with a 1 1/4 suction pipe connected to a shallow well pump.
After priming my pump the pump pulls up water for a minute and then goes dry. It doesn't appear that it stops because I have depleted all the water out of the well/casing pipe and the well needs to recharge. I say that because I can still see the water line in the well casing to be 10 feet down. If its an issue with recharging I would expect the water in the casing to draw down to the foot valve.
This led me to believe that I had a bad foot that would somehow close when suction was on.
However, here is the confusing part. I placed a hose into the casing pipe and turned it on while the pump was running. As long as the hose was on water was being pumped out of the well. (which means the check valve works) I then turn the hose off and then the pump goes dry again as I am looking at no water in the case drop below 10 feet.
Any ideas as this makes 0 sense to me. The well as acting as it needs to recharge but there is no draw down on the 10 foot water line.
Thanks
Thanks
