gking707
Looks awesome, after scrolling through the picture's my first thought was 'this guy definately needs to remodel his bath'
I hope you end up with a killer bathroom!
This is awesome, I can't wait to see the finished product.
Most 'thinset' mortars are not designed to be thick enough, are quite sticky, and not what you need. Another choice is a sand topping mix (really cheap) that is mostly sand with some portland cement in it. You can buy it premixed at about a 3:1 sand/cement mixture. When used to make a shower pan, you generally want more sand in it, but for bedding a tub, the off-the-shelf version at 3:1 is good...the higher cement ratio means it squishes easier. Lay some piles out, squish the tub down so it is plumb and level, then leave it for awhile. If you try to make a solid bed at the right height, you'll likely never get it done. Mix in enough water so that it is damp, holds together if you squeeze a clump, but doesn't drip water. Using too much water can make it shrink as it cures. It doesn't flow, or act like a cement mix you'd use to make a sidewalk, or foundation...it will look sandy - more like wet beach sand.
