Commercial water heater dielectric union
Discussion in 'Water Heater Forum, Tanks' started by Keith R, Jan 27, 2020.
  1. Keith R
    Keith R New Member
    Jan 27, 2020
    60647
    I'm the facilities manager at a not-for-profit youth center. I need to deal with three 1 1/2" dielectric unions (code requirement) on two 100 gal. water heaters. At least they appear to be 1 1/2". In each case a ring of corrosion has formed around the steel side of the union/galvanized nipple threaded joint. These joints each show a tiny leak at this point.
    What is the best way to confirm the i.d of the pipes without disassembling the system? Are they really 1 1/2" or maybe 1 1/4"?
    Can I replace only the galvanized nipple from the water heater body in each case and re-use the steel side of the union with a new flat rubber ring seal?
    Is there any likelihood that the galvanized nipples are actually attached to important inside parts of the water heaters (anode?)? Two of the corroded unions are bottom/side mounted inlets, one is the top mounted outlet. The outlet of one water heater shows no corrosion.
    If I have to replace the unions in total, I'd like to use Shark Bite couplings since the current press ring couplings don't leave a lot of room to work and I don't want to risk melting their O-rings by trying to sweat 1 1/2" couplers in the lines (my large diameter sweating skills are suspect anyway).
    Am I missing anything I need to pay attention to?
    Thanks.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Presume the pipes are schedule 40. Use a digital caliper to measure the OD. It will be 1.66 or 1.90.
    [​IMG]
Similar Threads: Commercial water
Water Heater Forum, Tanks Anyone have experience with an AO Smith BTX-80 commercial water heater? Nov 25, 2019
Water Heater Forum, Tanks Commercial water heater in a regular house? Jan 16, 2018
Water Heater Forum, Tanks Most Reliable Commercial (Gas) Water Heater? Apr 10, 2016
Water Heater Forum, Tanks Commercial water heater output Sep 15, 2011
Water Heater Forum, Tanks Swap from residential to commercial control on a gas HWH? Mar 15, 2019
