Reicherb
I've got a new polebarn with 1/2" pex tubing in the concrete slab floor. The slab is insulated underneath with rigid foam insulation. 2" I believe. The walls have 2" of rigid foam and 2" of closed cell spray foam. There will be 3 zones. primary building is 30x40x14. There are 2 smaller rooms that are 10x20x10.
There is a small bathroom that will also be the home of the boiler and a small kitchenette. directly behind the bathroom.
I plan to install a Weil-McLain AB-80C AquaBalance Combination Wall Mount Gas Boiler, 65,000 BTU (NG) but could be convinced to do something different.
I've read the manual at https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Weil-Mclain-383-100-030-User-Guide.pdf and have a few questions.
1. Do I need a DHW mixing valve? The manual says I do but it seems like with my basic pole barn setup where I'm really just looking for DHW for handwashing and with the fixtures being so close to the boiler, I don't need it.
2. I'm looking for help with circulation pumps. Is it best (maybe simplest) to do one pump per zone or do I use a single pump for all zones? Can you help me size the pump(s)?
3. I'm struggling to understand if the boiler has all of the controls and I simply connect everything or do I need some sort of external switching/relay device?
4. Am I ok to use ball valves to manually control the flow between primary and secondary loops? Why is this connection required on a condensing boiler? Does the return temp still need to be at a certain level?
5. Why would I use 2 wire zone valves vs 3 wire zone valves here? I've got 3 wire in the house.
