Cold and Hot Water reversed for entire unit
Yen4info
California
We had our lower unit remodeled and now the cold and Hot water are reversed for the shower, bathroom faucet, kitchen faucet and even the washing machine which is in the garage. Where can the problem be? Everything was working properly before.
Tuttles Revenge
The problem is where someone connected the cold to the hot and the hot to the cold. There are a couple potential remedies. The best solution is to connect the hot to the hot and cold to the cold.
Another solution depending on if the toilets are hooked up to hot and if you have certain shower fixtures with built in diverters or certain thermostatic valves.
All of the supply tubes under sinks can be swapped to correct the problem there. Most single handle shower valves cartridges can be flipped over to correct the problem there. If the toilets are connected to hot, and if you aren't solving the problem at the point of connection, then the water line would need to be swapped in the wall.
Is the toilet filling with hot or cold?
Is the dishwasher filling with hot or cold?
Outdoor hose spigot?
Is there an icemaker?
my guess is Yen4ever didnt do the plumbing and his plumber will need to come back Im sure theyll have a good Idea where it went wrong
