How important is it to have rounded corners( 90 degree bends) in the cold air return? I understand on the supply side of the furnace that you what the air to flow as smooth as possible, is this also the same for the return side? My return plenum and trunk are basically rectangle boxes, all the corners are square. Would this be a possible source of noise. I am getting a fair amount of noise for my cold air returns and I know part of the problem is the grilles are undersized. I will be making them larger and use better grilles( I have one grille that whistles). But is having the square corners in the plenum adding to the problem? It would take a lot more work to change, but will do if I need to.
System : Carrier 58mvc 80,000 btu upflow in basement
Cold air plenum is attached to the side,bottom 12x23 square corner
Runs up to floor joist 8ft., floor joist are boxed in square corner. Runs though floor joist for 6ft then down into 16x 8 trunk and up into a return in the wall( this is the one that whistles, also hear burner and clicking of gas valve), again square corner. Trunk extend 15ft to 2nd return.
Have added 8x16 return in basement off furnace side of plenum( basement did not have return). Did not seem to quiet the return on main floor. So should I remove the current return line and reinstall with rounded corners(keeping flow in mind as I do it) as well as install larger grilles?
