wbnethery3
I have a two-story house that is 10 years old. Over the holidays one of the toilets upstairs leaked into the ceiling above our bedroom. When I removed it, I found the original flange was quite rusty. We had seen a wet spot on the ceiling sometime last year, but it never got worse. I (mistakenly) assumed the problem had gone away and didn't go into the ceiling to investigate. This time, it leaked enough that I had to cut out some of the sheetrock to figure out where it was coming from.
Based on the staining on the subfloor, as well as the condition of the flange, I'd guess it has been seeping for a while. I need to replace it, and have been researching this issue. I've found various posts online that discuss how the flange is supposed to be positioned - some say it should ideally be installed over the finished floor, others say it can be as much as 1/4" recessed. In our case, I found the flange to be slightly below the level of the surrounding tile floor - best attempt to measure it was about 1/2".
I apologize - I haven't searched this forum for any sort of similar question... I trust the folks here to give good advice and hope it's a straight-forward answer. What is the industry standard for proper flange position?
