Clorox® Toilet Bowl Cleaner with TEFLON
Discussion in 'Toilet Forum discussions' started by Terry, Jan 11, 2006.
  1. Terry
    Aug 17, 2004
    Clorox® Toilet Bowl Cleaner with TEFLON Surface Protector
    Will I be able to see the TEFLON® Surface Protector on my toilet surfaces?
    No, the TEFLON® Surface Protector is invisible. In fact, TEFLON® Surface Protector modifies bathroom surfaces at a microscopic level and is far thinner than the width of a human hair.
    Does a film build up over time on toilet surfaces?
    No, once the invisible TEFLON® Surface Protector is in place, subsequent layers cannot build up on top of it.
    How long will toilet surfaces be protected?
    Laboratory tests indicate that the protective TEFLON® Surface Protector of Clorox® Toilet Bowl Cleaner with TEFLON® Surface Protector lasts for approximately 140 flushes before it begins to wear away.
    What is the advantage of having the TEFLON® Surface Protector in the toilet?
    The invisible layer that is applied to the surface by Clorox Toilet Bowl Cleaner with TEFLON® Surface Protector acts as a protective barrier against tough bathroom grime (such as rust or hard water stains in the toilet). Because these stains don't stick to the treated surfaces, the bathroom will stay cleaner longer. And, because it is harder for dirt and grime to stick to bathroom surfaces, subsequent cleanings may also be easier.
    Will I still have to clean if I use a TEFLON® Surface Protector product?
    Yes, because the invisible layers of TEFLON® Surface Protector wear away after time, repeated application of the products is necessary. However, the TEFLON® Surface Protector technology can help make cleaning easier by applying an invisible shield that helps prevents stains from adhering to bathroom surfaces.
  2. jk60
    jk60 Engineer
    Nov 20, 2005
    Engineer
    San Francisco
    Terry,
    Forgive my confusion. Is this a new product that you've run accross or is this a product that you have experience with and you recommend?
    Thank you,
    Jerry
  4. Terry
    Aug 17, 2004
    Bowl staining. best way to prevent a bowl stain.
    I've used it.
    It does keep the bowl cleaner.
  5. jk60
    jk60 Engineer
    Nov 20, 2005
    Engineer
    San Francisco
    Thank you for the information!!!
    Jerry
  6. Dellar
    Dellar Guest
    I use this product, it works great. I'm glad somebody thought of this. The regular spray surface cleaner works really good too on sinks, tubs, etc.
  7. Spokaneman
    Spokaneman New Member
    Dec 14, 2005
    Spokane WA
    Is this ok to use with SaniGloss?
  8. Terry
    Aug 17, 2004
    I'm finding out the hard way. I'm using it on all my toilets, included the Sanigloss Ultramax.
    I will keep you updated.
  9. Snowman
    Snowman New Member
    Mar 17, 2005
    Retired math teacher
    FLORIDA
    Product Review.......
    I've got to tell everyone about my experience with this product. In twenty words or less...... IT WORKS !!! :)
    Thanks Terry, it does just what it is supposed to do even those areas that are on the sides of the bowl. I love to find a product that works. :rolleyes:
    see ya, Tom
  10. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    Yup. Great product worth talking about. It's a winner. I experimented with the slippery-ness just by rubbing it between my thumb and index finger and it is far more slippery than oils or silicone imo.
    It is unlike so many of these products that are marginal or just rely on the cleansing property of water.
    Lasting for 140 flushes? maybe, I suppose.
    I think that would depend on the amount of debris-not just number of flushes. Perhaps different in every home, is my non professional guess.
    When they find out how well it works they will probably start marketing Teflon toothpaste etc....lol.
  11. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    Terry - how did the Teflon work on the Sanigloss. Any better or worse than Sanigloss alone. My gut feeling is that it would have a harder time sticking to Sanigloss. Sending micro-nano particles into a septic system may be a long term problem.
  12. OldPete
    OldPete DIY Senior Member
    Jan 4, 2006
    NJ
    I am about to install the Kohler Cimmaron -- I have heard that keeping it clean is NOT easy... Part of me wants to return it, and buy the Toto, another part of me says that *this* may be a help...
    Funny, seeing how I don't even know if I'm going to have a problem keeping the Kohler clean.
    But thanks for the info. :)
    Pete
  13. maddog
    maddog Engineer
    Aug 1, 2006
    Software Engineer
    near San Jose, CA.
    Kohler Cimarron
    I installed a Cimarron (elongated) with a Fluidmaster Flush 'n Sparkle gizmo (http://www.fluidmaster.com/care_products_8300.html) and haven't had any problems keeping it clean. I installed the bleach formula to keep my wife from throwing those chemical disks into the tank!!
  14. Terry
    Aug 17, 2004
    Teflon on the Sanigloss.
    That's what I've been using.
    I flushed it the other day, and whoosh, it was all gone! I don't mean the Teflon, the other stuff was gone.
    The Sanigloss is nice.
  15. alternety
    Apr 2, 2006
    Washington
    I have a problem with my internal workings and diarreha is an ongoing and daily problem. Is there anything better than the UltiMax + Sanigloss for keeping the bowel clean under these circumstances?
  16. Terry
    Aug 17, 2004
    I was all ready to try the new Toto Soriee with Cyclone flush, but then I got a call and I sold it before I could install it. The Ultramax with Sanagloss does work pretty well though. That's what I have downstairs.
    That one has Sanagloss and has water swirling around the bowl.
    I have another one on order, this time I better just install it right away for myself. It will be going in the Master.
  17. Jeff1
    Jeff1 New Member
    May 24, 2006
    So Cal
    I have the Cimmaron - standard bowl - and don't have any problems keeping it clean. If there is any residue on the bowl, the next flush seems to take care of it. This product does seem like it will make it even better though. Thanks Terry.
  18. mekump
    mekump New Member
    Mar 24, 2006
    Computer Eng
    Maryland
    Hello,
    So, what were you all using prior to this on the toilets with Sanigloss?
    Mike
  19. jadnashua
    A swish with a brush was all it usually took.
  20. mneubecker
    mneubecker New Member
    Oct 19, 2006
    take my word for it, return the cimmaron and go with the toto
  21. roboman
    roboman New Member
    Oct 22, 2006
    Maryland
    I would not recommend that. I have the Drake and it does not clean very well. You can see that the water goes straight down without an swirling that helps clean the bowl.
Similar Threads: Clorox® Toilet
Toilet Forum discussions Squatty Potty for handicapped toilets. Yesterday at 9:57 AM
Toilet Forum discussions Tried to replace flush valve, now toilet is running Yesterday at 8:18 AM
Toilet Forum discussions ROTO Wipe, saving toilet paper one tree at a time. Sunday at 4:42 PM
Toilet Forum discussions Penguin toilet Friday at 3:44 PM
Toilet Forum discussions Another toilet running Friday at 10:12 AM
