Hcw3
This might sound a little odd, but if someone could advise, I'd appreciate it.
We have a chlorine injection system with a holding tank for the Clorox solution.
Normally when I mix the Clorox solution up in the tank (using softened tap water), the Clorox solution ends up just a little yellow, but still perfectly transparent.
This time, after mixing up the solution, it ended up foggy or milky in the tank, & not yellow. That's never happened before.
I've done nothing different. Concentrated Clorox, same ratio.
Tank was thoroughly cleaned recently.
I've sniffed the bottle, and it seems it should smell stronger, but my nose might not be reliable.
What does the milky vs transparent solution indicate?
I'm considering dumping it and starting with a fresh bottle of Clorox.
TIA
TIA
