Rman
Master mechanic
I plumbed my house with oxygen barrier PEX tubing 3/4 inch from hot water boiler to copper fin baseboard radiators
This is a two story home with basement where the boiler is installed. Every time there is a call for heat upstairs the areas in the wall where the tubing goes thru the top plate to radiator starts a tick/click song for about 20 seconds as pipe heats up not the baseboard radiators. Can I spray a silicone product from above the floor (or a similar product if you can recommend) to let the PEX expand easily not rubbing on the wood 2x4’s. The holes I drilled were oversized but the natural curve of PEX rolls and fire break spray foam into the holes must be restricting the expanding PEX. Also any thoughts if this constriction can shorten the life of the PEX? Thanks
