Clearing lavatory vent stack
Steve42
Alabama
A couple of years ago, I called out a plumber because both sinks in our guest bath were draining incredibly slowly. He went into the attic with a small electric auger and ran it down the vent stack. I know that he carried a bottle up there to lubricate the snake as it went down, and he said the clog was only about 10' below the vent stack opening.
The same sinks are acting up again and I'd like to try and clear it myself because I just changed jobs and haven't gotten a paycheck from the new company. I have a 25' sink auger that I'd like to try to use. I think it's one that you can connect to a drill rather than using the handle.
I would guess that the plumber was using dish soap, possibly mixed with water, to pour down the snake. Does that sound feasible?
I have not heard of using a lube. I was able to run water during the cleaning. Dish soap sounds good to me.
Here is my limited story cleaning a lavatory drain blockage.
My situation was that I could remove my strainer and I did not have a pop-up-drain rod to block the path. That will not be the case for most.
Have bathroom lav that started to drain slow has aav not a vent. Pull the trap shop vac on piping vac pulled toothpaste and hair out of it for at least 20 minutes. Have no idea how its piped. House was 18 years old had 3-4 kids when i bought it 2 owners.
