CenterTree
Anyone here use this extensively?
I have a need to make a DIY site tube for the outside of my indoor water storage tank. (low yield well water).
I figure a simple TEE off the bottom discharge hole, and then run the clear pvc up the side of the tank. Add a float ball too, just for kicks.
I have found there are basically 2 sources of this pipe. One expensive one brags of NSF/potable rating. And the cheaper one claims to be "furniture grade". Quite a price difference. Do you guys think there is a REAL difference in material or might it just be the high cost to get the certification that makes one more costly?
Looks like all the other specs are the exact same as white schedule 40 in respect to both.
NSF pipe:
https://www.clearpvcpipe.com/produc...1&_sid=33c1ce0eb&_ss=r&variant=40024262639767
https://cdn.shopify.com/s/files/1/0...VC_Brochure_-_Schedule_40_80.pdf?v=1618841513
CHEAP, not rated pipe:
https://www.homedepot.com/p/Formufi...VC-Pipe-in-Clear-P001FGP-UV/206028393#overlay
NSF pipe:
