Rossn
My main drain stack turns to 1960's cast iron before going through the slab. It currently has a plastic cleanout plug (square) that doesn't easily budge, and it is recessed into the wall. I am tapping into the drain immediately above the cast iron today, for a washer drain.
Is the plug likely to be removable with enough force, or should I consider an extension or installing a cleanout higher-up?
The stack will be concealed behind tile. The cleanout currently points towards at the back of a laundry room cabinet. If I installed a cleanout higher up, it would be near the top of the interior of the cabinet, around 33".
