atlld
I am purchasing a house (built 1955). I had the sewer lines scoped and the plumber discovered an issue.
The kitchen was recently relocated. The new 2 inch kitchen drain was brought all the way down a wall in the basement and connected in to what we assume was an old floor drain. The concrete slab was opened up and the drain removed. A section of 3-inch PVC was joined to the cast line, and stepped down to the 2 inch kitchen line, all underground and now covered in new concrete. There is a clean-out on the wall section, but only 2 inch.
From the scope video, we know that the cast drain line is badly scaled and in some places the available diameter is quite small. The plumber said that feeding the new 2 inch kitchen line into this old cast iron line will result in issues sooner or later. He said that the cast line should be cleaned, but because of the improper installation, it can only be jetted. There is only a 2 inch clean-out! A 3-inch blade can't fit through the clean-out.
What should have been done is to bring the 3 inch line up out of the floor, with a 3 inch clean-out, and connect the new 2 inch kitchen line above that. This way, the old 3 inch cast sewer line would be completely accessible through a 3-inch clean-out.
My question is this. I have a small window to ask for repairs here. Should I just ask for jet cleaning and resign myself to having to do jetting forever in the future? Or, should I ask the seller to open the floor and bring the 3 inch line up to a 3 inch clean-out.
I called a reputable plumbing company and based on my description of the job, they quoted $1,000 to open the floor and make the repair. I have been told that jet cleaning can be $350 typically. I am inclined to request this be repaired properly, but am I making a mountain out of a mole hill?
Thanks!!
Thanks!!
