electrotuko
Clack WS1EE used on a iron removal filter/tank, Backwash only valve.
After a month after an installation it started leaking from a Refill Port Plug.
The water drips (1 drop/hour) from the locking clip holes.
I removed the plug, visually inspected, all looks good, O-ring looks good, clean.
Lubricated with silicon, re-seated. Still drips.
Removed plug again, removed O-ring, wrapped few turns of Teflon tape on the plugs neck, to make O-ring sitting higher, making more tight contact O-ring – Valve body.
Still the same.
What can be a root cause?
Still the same.
