Bfgoodmudder
Hello, I’ve been reading posts trying to find my issue but it appears that when I open my water valve and allow water to flow, it stops the injection of chlorine due to water pressure. I can’t seem to find any other issue. The injector I’m using doesn’t look like other injectors I’ve seen but it’s the only one I have. Not sure if that the issue. I’ve verified the pump is working all the way through the injector and pumps into the water system and I can see the feed hose reacting to each pulse. When I turn the water on, it builds pressure and the hose stops reacting to the pulse, like it stops the flow of chlorine. Tank level isn’t dropping and I can’t detect any chlorine in my water supply. So I was hoping to get some thoughts on the possible issue. The injector has a small foam wedge where most injectors I’ve seen have a stem that protrudes into the water supply. Is that the issue maybe or something else. Any thoughts? Thanks in advance!
