Greg Mueller
First let me describe my system......
I have a 600' well.
When the float in my 1100 gallon cistern closes the well pump fills the cistern through the upper inlet.
Out of the cistern's bottom (outlet) I ran a poly line about 250' to a smaller (300 gallon) holding tank in the basement. The 300 gallon tank is fed by gravity from the 1100 gallon cistern. Before entering the 300 gallon tank the water goes through 4 Big Blue filters (in parallel) just to take out dirt and rocks.
The water sits in the 300 gallon tank until water is required in the house.
A pump then runs it up to 45lbs pressure. From there it goes through 4 more Big Blue filters and then through a GE Whole House osmosis system which back flushes once a day.
The water is clear but has a slight sulfur smell.
I would like to introduce some chlorine into the water just to make sure there are no bugs (bacteria) living there although the osmosis system is suppose to remove anything that large.
The simplest thing I can think of is to mount a drip system on top of the 300 gallon tank and let it drip an occasional drop of chlorine in to the 300 gallon tank. I would not have to cut up the system that way for some kind of injection system......
Suggestions appreciated.
Thanks
I have a 600' well.
Thanks
