Chlorination injection pump for well water chlorine to water ratio
Bill R.
New Jersey
Just a quick question. I have a 30 gallon tank that a chemtech pump is attached to which injects a chlorine solution into my water. I wasn't left any manuals as it pertains to the ratio of bleach to water when filling up the tank. Can anyone please provide assistance?
Thanks,
Bill
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If you mix the chlorine in the 30 gallon tank and make it strong, the Chem tec needs to be set at a low number. If your mix is weak, it needs to be turned up. You really won't know how much you are adding until you do a chlorine residual test.
