Hi all,
Here's the problem I'm having. I was clearing a clog in the wall coupler (not sure this is the right name for the part, I'm talking about the piece that goes from the p-trap to the metal drain pipe sticking out of the wall) underneath the kitchen sink in my rental unit. It does not look like the connection to the metal drain pipe was sealed and the threads are very corroded, so when I removed the wall coupler a small piece of the end of the drain pipe chipped off. This is what it looks like... you can see the chip along the top edge of the pipe, it's about 1/4" deep.
Now when I reconnect everything, there's a small leak at the joint with the metal drain pipe. It doesn't seem like pipe joint compound would do much; maybe tape would help. Any advice on stopping the leak? Seems like the proper fix would be cutting the pipe and some new threads, then buying a slightly longer coupler and properly sealing the joint, but I don't want to do all that if there's a simpler (if jankier) fix.
Help greatly appreciated.
