Ginahoy
Building Systems Engineer
I'm designing a new home with fully below-grade basement. There will be a sump pump to lift basement wastewater to the main sanitary line that runs through the floor trusses. The trusses bear on the basement wall so the main sanitary line will exit the house about 12" above grade, then elbow down to grade on the outside of the basement wall, assuming that's allowed.
If not, I'll have a challenge routing the line so that it can exit the house below grade, in which case I will post further details for advice.
Thanks
Thanks
