So my hot water on all lines all of a sudden is very low. I turned everything off and opened the hot line and cold line to check. First of all my hot water supply is coming out of the part of the water heater that says cold, and the cold water in from the street is going into the hot. That sounds wrong.
First after turning everything off I opened my hot tap in my laundry room and shut off the cold to the water heater. I tried to drain the water heater throuh the drain line. This was slow and while I was waiting I took off the cold water line, in doing so I found this cermic ball with a point. I pulled it out and connected the line again and turned on the cold, and everything is back to normal. Before resuming normal operation though I want to know if anyone knows what this is and if its needed or dangerous to operate without it?
