Ceiling fan install
Kristina James
Oklahoma
We installed 3 ceiling fans into our sunroom. We were just replacing them so they were prewired. We have put red to blue, Black to black, and white to white. There are separate light and fan switches and one switch box is in our room and one in our living room. When we flip the light switch the lights come on. However, when we switch the fan switch on, nothing! What are we doing wrong?
One switch controls 3 fans? Or one independent fan switch for each of the fans?
One switch for all 3 fans
I would suspect power is not getting to the fans. Can you slip a wire under the insulation to probe closed-end wire connectors? Don't get shocked.
It seems to me that wirenuts would have made for easier troubleshooting. I am not an electrician.
One more thing to check. Have you operated the speed control for the fans? Could they all be off at the pull string switch?
Kristina James
Oklahoma
We have figured out the issue. The switch in our room is just a single pole switch! So it was in the off position. It can kill all power so you can’t turn them on from the living if that switch in our room is in the off position. ‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️‍♀️
Kristina James
Oklahoma
Question: provided all the proper wiring exists. If we replace this single pole with a 3 way, everything should work, correct?
