Hi out there
I replaced my shallow well pump to get more pressure to a second floor shower. I bought a 3/4 hp 30/50
red lion from home depot. It is connected to an expansion tank and a 10 ft deep well. The pressure switch closes and then the pump will run on and on and not build pressure. If I shut off the pump for a second or two and restart then, the pressure builds normally . Next time the pressure drops it's the same thing all over again. The pressure side of the pump has a priming port to which I installed a valve to bleed air out and prime but it still goes through the same cycle. Why would shutting off the pump momentarily "fix" the problem ? Anyone had a similar issue? It's spring and the water table is high.
Thanks
Wally
Thanks
Wally
