index1489
This is a 2005 construction slab 2 story single family home in Southern California.
The house is all ABS, with the exception of this cast iron 2 inch pipe that goes into the slab and transitions into ABS at the top of the wall for the master bath sinks on the 2nd floor.
The top no hub pulled off the ABS and leaked into the wall.
I believe they ran the ABS a little short and had trouble getting the no hub to seat correctly, I'm planning on cutting it out and bringing it down about 6 inches past the metal bracket then reinstalling the cast iron pipe with two new couplings.
I was also considering if it would be better to just run
ABS all the way down to the cast iron stub in the slab.
Thanks for any and all advice and input!
