FixerLady
Hello all, I've been pouring over the forums here and want to first thank everyone for contributing to these forums. I'm in the middle of a bathroom remodel have moved the shower and toilet to new locations. This is my home and I'm doing the work so before I close things up I wanted to post some pictures here to verify that I'm on the right path.
1. The main soil pipe under the house is cast iron, I've tied into it with a new 3" ABS wye and 45 using Fernco P3000-33 couplers. My question here is, are these the right couplings? I've cleaned the cast iron with a wire cup brush and they slid right on with no problems. I can twist the wye around fairly easily and before I torque down the clamps I wanted to verify, should the rubber be tighter around the cast iron (before torquing the clamps)?
2. This is a little trickier. To tie in the shower and get the right slope, I've had to cut the old cast iron wye below the hub. *I realize this was a bad decision but there isn't much room to install a new line without removing all other cast iron that's touching it. I've installed a doughnut inside the wye, it's quite tight and with the 2" ABS it's not coming out easily. For added peace of mind I also want to install a Ferco 3"x2" coupling on top of all that. What do you think of all this?
