FoakPa
1950's bathroom with wallboard & plaster walls...has been completely gutted...down to 2 x 4 walls now
Sorry if this has been ask before....
Just purchased Kohler Villager Cast Iron Tub 60" x 30" X 14" ( 318 lbs ).....installing to a 5' x 8' bathroom.
Installing tub along the 5' wall......The wall with plumbing was built with 2 x 4 and then firred out another 1 1/2" with square stock....
I have removed the 1 1/2 firring strip to add more room for install....
My question: What is the easiest way to get it installed...& leveled with metal shims ?????
Do I tilt on end & slowly lower down with 4 huge guys handling weight; with 2 guys slowly lifting up on one end & 2 guys lowering on the other end......and inching & working it down slowly.....
Only have about an extra 2" or so.....playing with a length of 62 1/2"...not much room to work with...but maybe that is all I need with 4 guys manhandling it....
Also, what is the best way to get shims under the feet.......
I have a stem wall raised foundation ......so I have access underneath the bathroom & tub for the drain area and all plumbing.
Your advice would greatly appreciated....Thanks in advance...
