Scott123
Based on my pipe dimensions and a call to Fernco, I've got the right donut size. Without the PVC, the donut slides into the CI pretty comfortably, and, outside the CI, the PVC slides in as well. But, inside the CI, no amount of manhandling is getting this PVC pipe into this coupling.
I've tried:
1. Liquid soap as a lubricant.
2. Inserting the donut halfway into the CI and then hammering the PVC using a wood board
3. Tapering the edge of the PVC
The PVC is so sharp now that it's cutting into the ribs inside the donut.
I'm considering
1. Reaming the CI opening with either a drum sanding bit or maybe a grind off wheel
2. Heating the CI
3. Heating the donut in the hopes that it might get a bit more malleable/compressible
4. Sanding the (neoprene?) donut with very fine grit paper
5. All of the above
My CI opening is maybe 1/32" less than 3". I'm not finding any drum sanding 2.5" bits that I can get my hands on today locally. Heating and sanding the donut also makes me a little nervous, since replacing it is a two hour drive.
This thing is really kicking my behind. Any advice is welcome.
I've tried:
I'm considering
2. Heating the CI
5. All of the above
