Cast Iron to PVC - Donut / Cap sizing confirmation
timeforsaving
Colorado
Converting a home from cast to pvc, everything is busted out except for a cast iron wye(?) in the floor. Formerly there was a coupling here, but wondering if a donut would be a better solution, less for something to get caught on since I'm redoing it. Breaking out the interior pipe without busting the hub is going to be a challenge probably?
In the first photo, if I buy a fernco P44u(x)-405, does that seem like the right size and everything?
In the cleanout photos, the current cap is pretty damaged, whats the best approach here to cap, a clean-out style plug? Which one would it?
Thanks in advance
That donut route makes sense for a floor wye if the hub is still sound, since it keeps things flush and gives you less to catch on. Before you order the 405, measure the inside of the hub after you clean the rust out, because old cast hubs vary and that measurement is what sets the donut size. For the damaged cleanout, I would not try to force a new threaded cap into chewed threads. A rubber expansion plug is the safer temporary cap, and if the fitting itself is cracked it is worth replacing that section while everything is open.
Hi @Steven Lee , thanks for the response, just like you said, I got the interior of the pipe removed and oakum stuff removed and cleaned up. the interior is 5 1/8 or a just a hair under. The 405 donut is like 4.77... so that wont work. Now what?
That 5 1/8 measurement explains it, a 405 is just too small for that hub and forcing it in will not seal right. I would measure it in a couple spots first, since old hubs are often out of round, and check whether that is actually a 5 inch hub. If it is a worn out 4 inch hub, I would not chase a bigger donut. Cutting the hub off and using a shielded no hub coupling on the pipe itself is usually the cleaner and more reliable fix there.
A digital caliper is useful for measuring that hub ID.
