weightoomuch
I have 10 feet of cast iron pipe connecting an outside cleanout to a crawl space. As the pipe enters the crawlspace it is above ground and I am planning on connecting the existing cast iron section to a stick of 4" sch 40 PCV to drain and vent a bathroom. I went to make the connection with a Fernco Proflex P3000-4 that is shielded for above ground and made for 4" SV cast iron, and 4" sch 40 PVC. It does not fit. The cast iron pipe does not have the standard OD for 4" cast iron of about ~4.38. Instead the cast iron pipe has a OD of about 4.2". Have any idea what type of pipe this is? Coincidentally PVC Plastic SDR 35 Pipe has a OD of about 4.2. I was thinking about using a SDR 35 to PVC sch 40 no hub connector to make the connection, good idea?
Thanks,
Thanks,
