Joe41561
Hello all,
I attached a drawing of this. The house is almost 50 years old. I have a small leak in a vertical cast iron pipe in my basement. The cast iron section is about 5-6 feet high from the clean out at the basement floor and joins a 3" copper drain near my basement ceiling that goes all the way up through the first/second floor and attic. This is what I am thinking of doing to repair the pipe, please let me know if it sounds like a good plan.
1) Install riser clamp to secure the 3" copper drain pipe, in case it is not well secured by the original plumbers
2) Cut the copper drain before it transitions to 4" cast iron.
3) Cut the 4" cast iron 2-3" above the cast iron clean out (the leak is about 4" above the cleanout so this is going to be close).
4) Use shielded fernco to go from the 3" copper drain to 4" pvc pipe with a pvc clean out at the bottom (don't want to test fate by opening cast iron clean out in the future) and then a shielded fernco from pvc pipe to cast iron.
What kind of riser clamp and how many should I use for the 3" copper drain? I found a copper epoxy coated riser clamp which I thought would be good to avoid possible corrosion since I've read galvanized metal clamp might corrode with the copper pipe over time. Links below:
Here are the parts that I am looking to use:
Riser clamp:
http://www.supplyhouse.com/Empire-Industries-50CTI0300-3-Copper-Epoxy-Coated-Riser-Clamp
Shielded ferncos:
http://www.supplyhouse.com/Fernco-3...st-Iron-to-PVC-Steel-or-Extra-Heavy-Cast-Iron
http://www.supplyhouse.com/Fernco-3...ing-PVC-Steel-Extra-Heavy-Cast-Iron-to-Copper
Thanks in advance!
Riser clamp:
Shielded ferncos:
Thanks in advance!
