EthylOH
Hi all,
I'm in the process of remodeling my bathroom. Since my old plywood subfloor had a lot of water rot, I had to remove it. This necessitated removal of the old cast iron closet flange.
Here's the problem...
The drain pipe inside the flange was cut way too short when they originally built the house in the 1960's.
The old floor consisted of 1x10 planks, 3/4" plywood, and then 1/8" tile directly on the ply. (total = 1 -5/8 ")
My new floor will consist of the 1x10 planks, new 3/4" ply, 1/8" Ditra, and 3/16" tile. (total = 1-13/16")
The drain pipe is approximately 1/4" below the plank floor, so when all is said and done, I need about 2" of depth just to reach the top.
I've looked all over the internet for options, and I can only find a few:
1) Cut the cast iron pipe, and add a no hub to PVC.
2) Drill out the lead in cast iron hub below and remove the pipe. Then add a rubber coupling for PVC.
3) Replace the flange with another cast iron flange and fill with molten lead
4) Use a push-in gasket fitting (Supply House has a cast iron flange: http://www.supplyhouse.com/Jones-Stephens-C47440-4-x-4-Two-Finger-Flange stock picture isn't accurate - it has a 4" throat)
Options 1 and 2 would be a nightmare due to the joist right next to the pipe.
I like options 3 and 4. I wouldn't be opposed to replacing it with another cast iron flange, but I can't seem to find them anywhere.
I've attached pics to show the problem. Any thoughts or suggestions would be appreciated.
Thanks in advance.
Thanks in advance.
