Hi, everybody. New to the forum and looking for some advice. I've spent the day researching the issue and haven't found my specific problem addressed.
I'm looking to remodel a basement shower that has concrete block walls and a sloped concrete floor.
In the "middle"(sorta) of that floor is a big 7.25" cast iron drain screen. Next to the drain is a clean out that accesses the other end of the p trap. It doesn't look like there's any kind of pan liner other than maybe something painted on. My intent was to use the existing floor as the pre-pitch. Put a vinyl pan liner on top of it, put furling strips on the walls and attach a backer board and moisture barrier, lay my top mortar bed and then tile everything in.
All this rests on my ability to find a way to replace that big nasty, corroded scary drain with a three piece shower drain. Any thoughts on how I might do this? Is there a product that could fit down inside that 2 inch drain or anything? Is my only option Jack hammering through the floor and replacing the p trap and the drain with pvc? Any advice or recommendations are appreciated.
