Casing repair sleeve, aka well liner. any non-PVC options?
AnantaSesadas
North Carolina
I have bad corrosion in my well casing. Inspector said it will just get worse and the sooner I get a liner the better for keeping the well usable. But he uses PVC to make the liner and I want to avoid using that material. Is there any other material that can be used to line a casing like a repair sleeve?
AnantaSesadas
North Carolina
I'm learning that vitrified clay or cement pipe might work but if I can find HDPE or ABS pipe that would be cheaper and easier to install. One reference suggested these latter plastics but everywhere I find ABS it is described as DWV and not for pressure. Well won't be under pressure except by any soil that builds up from the deteriorating case. So it looks like only HDPE is an option.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yeah and the wall thickness of HDPE will be too thick to work, and it will be too flexible as well. I don't think PVC is as harmful as some would have you believe. My casing, drop pipe, underground pipe, shroud, and all the fittings are PVC. Me and a lot of other people would have been dead a long time ago if PVC was a real problem. Plastisizers leach out of PVC for a while, but after a few years it declines greatly. And if you have rust or anything in the water, it can coat the pipe with a patina as well.
VAWellDriller
Active Member
Richmond, VA
Its definiltely not DIY.... but I've installed both black and stainless steel liners in wells..either is a good alternative to PVC if you are dead set against that.
