case 3200 replacement
david mariant
sacramento, ca 95821
Hi Terry,
I am debating replacing the case 3200 with a standard wall mount 4 bolt design. I reviewed your discussion about the case 3000 and found it informative. Will the case 3200 carrier be similar to the one for the case 3000? Do you have a picture of the wall with the hanger support before removal of the hanger and opening of the wall? I am trying to put instructions together for a plumber to do this change over.
Any additional before and after pictures for this 2 bolt to 4 bolt conversion?
David
BECplumbing
Plumbing Apprentice
Louisiana
Hi Terry,
David
those case wall mount toilets usually use a 4 bolt Carrier where only the bottom two bolts are used. You will need to open up the wall to add 5/8 all thread rods. If for some reason there is no place to add them
Then you will need to replace the carrier. In the event that the carrier needs to be replaced here is a replacement carrier https://roofdrainexpress.com/josam-...aZ9rbDBcpIreEJSsGYQPOKFq73OfokWhoCszUQAvD_BwE
