Case 3000 fill valve replacement issue
msoreco
San Diego County
Hi all, new to the forum here. We have a 1964 home with 2 Case 3000 toilets that have had the fill/flush mechanism replaced with a hodge-podge of brass and PVC pipe and standard modern fill valves. I am in the process of reverting one of them back to the original Case fill valve. Got the toilet remounted to the wall with a new outlet seal so that's done, now working on the fill valve assembly installation and am having some issues with that.
The fill valve that I received from Chicago Faucet Shoppe is part number 5150. It looks like the order of assembly should be to loosely install the vertical water supply inlet assembly first, then attach the flow adjuster/riser tube assembly to it, while simultaneously plugging the threaded water outlet and rubber bushing that it plugs into, in to the associated port in the tank. However if I put the bushing in the port first I can't get the threaded outlet to go into the bushing, and if I put the bushing on the threaded outlet first I can't get it to go into the port far enough. Interestingly, the original assembly must have used a flexible plastic tube for the water outlet instead of the threaded brass outlet, since the old bushing that I removed from the port had a smaller diameter hole in it than the bushing that came with the new fill valve that I received.
Attached photo shows the new part's water outlet with supplied bushing, next to the old bushing I removed from the port.
Any hints how to get this thing installed? Fought with it a couple hours already with no luck.
