Caroma vs. Toto
kc1121
California
Trying to decide between the Caroma Sydney 270 Elongated, the Toto Aquia II CST416M or the Toto Eco Drake CST744E -- any assistance would be greatly appreciated. All 3 seem to do a excellent job of water conservation compared to what I currently have installed. I guess my main concerns are bang for the buck (after rebates), flush power and ease of installation for the plumber/contractor/myself.
Thanks in advance
The best bang for the buck will be the Eco Drake, 1.28 gallon flush with a very simple installation.
The Caroma is the most expensive of the three, and the installation is a little harder than the Drake
The Aquia is between those in price, a little more time on the install than the Caroma, but a nicer toilet than the Caroma.
kc1121
California
Actually, in terms of price (cheapest first), it went Drake, Caroma, Aquia II. With the addition of the soft close seat for the Totos, not sure if the Caroma included the seat or not.
Thanks for the quick reply.
kc1121
California
Can't recall where I read/heard it, but is it possible to swap the flapper or make adjustments to the EcoDrake to give it an even stronger flush(G-Max?)?
If you change to the red flapper or blue flapper it drops more water,
or you can just hold the handle down a bit longer.
I have one in the master right now, and I don't even think about it.
The Eco Flapper works just fine.
attachment.php
E-Max flapper THU277S
Peanut9199
Ontario, Canada
Eco-Drake you can remove the float and it changes to a G-max.
Remove the chain from the trip lever, remove the round white clip, slide float off chain and reconnect chain to trip lever.
GramGram
California
I finally went with the EcoDrake...
...and I wouldn't know why you would wish for a more powerful flush. I think it is TERRIFIC as is. "If it ain't broke, why 'fix' it?"
Peanut9199
Ontario, Canada
If you change to a Blue flapper you would let out even more water.
E-max 1.28 GPF
G-max 1.6 GPF
Blue flapper probably 2 GPF
kc1121
California
thanks all.. just trying to gather as much info as possible before I go after 3 EBMUD rebates ;)
GramGram
California
EBMUD Rebates
Yes, I need to get a second toilet for a hardly used Master Bathroom.
I have until the end of December and I'm thinking I should stick with the EcoDrake. After Rebate, the price will amount to 72.00 but we got the self-close seat which was pricey--40 BUCKS!!! I would never have gone for it except for the rebate. Question is, does Toto make any other (less pricey)seats? I hate to get a different brand since the "made for a Toto" looks so nice.
kc1121
California
on the spec sheet for the EcoDrake EL, they list 3 seats: the soft close and 2 others -- so there are other Toto options it seems
Any elongated toilet seat will fit...depending on the brand, it may not be a perfect match to all of the curves, but it will work fine. The softclose seats are available made in different materials, and with security bolts (so it can't easily be stolen).
There are only two seat sizes in the US.
Regular
Elongated
The Eco Drake bowl can be ordered four ways
Regular
Elongated
Elongated with CEFIONTECT
Elongated with ADA height
kc1121
California
after a little shopping around this weekend, it looks like the Caroma is out of the mix and another Toto is in the picture now.
Still w/ the same parameters from the original post (bang for the buck, flush power, ease of installation, etc) -- which would most of you choose: the Eco Drake, the Eco Aquia II or the Eco Ultramax? Adding the soft-close seat to the Eco Drake and Aquia II make all 3 toilets within a range of $30-40 for me, so no major difference of prices.
