Carlyle or Aquia 11.5 rough in
Socialrez80
Maryland
Hi. My rough in is 11.5 or 11 3/8 from the wall so to not risk it, I have to go with Aquia Or Carlyle 2 so I can use the 10 inch unifit in case it does not fit. I have been reading complaints about the Aquia because of bowl shape that some smears can be left. Any opinion?
secondly, does the Carlyle come with the washlet + hole pre drilled. I have a hard time finding. A washlet + combo in stock so I want to piece meal it but hoping it has the hole pre drilled.
would appreciate any advise and thanks for all you guys do here.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Yes, smears with the Aquia...but worst of all is the unforgivable design of the stupid plastic block mount with flat head screws to attach the unit to the floor.
I don't know the washlet hole answer. Talk to Toto or a Toto wholesaler.
Most 12 inch rough toilets, will fit an 11.5 inch rough, and probably even a 11.25 rough. The exception is if the wall leans out.
Some 12-inch toilets have more space there than others. Plus you can gain a bit extra by sliding 1/4 inch closet bolts in the slot a bit.
Other than your concern about the rough in and good flushing, what characteristics are you looking for. Elongated, chair height, one-piece, cost?
Note that many rather different toilets can have names such as Drake, Aquia, Cadet, etc. So pay attention to the model numbers in discussions.
Socialrez80
Maryland
Thanks for the replies, much appreciated. I certainly want a one piece, and elongated. I have heard chair height is more comfy so would like that too although not a requirement. I put a level on the back wall and it was not completely straight, so it worries me a bit. I can send a photo, when I get back to the house later. I am still torn to wait for a washlet + or just get a washlet and let the wires show. will respond will pictures. Thank you all for advise.
Tuttles Revenge
Buy the toilet with the hole pre drilled.. If you're still on the fence whether to buy one or not, the toilet will come with a seat that covers the hole. You can decide later.
Look carefully at the spec drawing on the Carlyle and I think you'll find that it normally sits 3/4" from the wall. If the wall doesn't lean into the room, it should fit. Normally, you can shift the toilet 1/4" or maybe 3/8" on the bolts. The toilet flange's opening is about 3", and the outlet of the toilet is 2-1/8", so shifting it slightly will still have that pointing down into the drain.
Tuttles Revenge
The toilets with a Unifit come with the standard 12" fitting regardless.. Buying the 10" rough can't hurt, you'll have it on hand when you set the toilet and be able to use it if the 12" doesn't work.. and if you end up not needing the 10" Unifit, you can likely return it or sell it on ebay or whatever.
*edited the length of unifit i suggested from 14 to 10*
FWIW, if your rough in is less than 12", and you're uncertain a 12" one would fit, with some Toto models, you could pick up the 10" rough-in, and be assured it would, but it would likely stick further out into the room.
When the rough-ins are exact, whether 10, 12, or 14", with those Toto toilets that use the UniFit adapter, the actual toilet sits exactly the same distance from the wall...only the internal UniFit length changes to compensate.
The Carlyle normally sits about 3/4" off of the wall, so, in theory, if you had 11.25", the rear would be touching, but you can often fudge the position on the flange slightly to move it forward while still maintaining a good seal to the flange. You don't want the rear touching the wall.
